I have some carbs for type 4 engines.
First up is an Italian Weber 32 36 progressive with red powder coated manifold set.
The red is nicer than the photos. It's for 1.7 and 1.8 I have run it with a 1.8 and works well (cant find the air cleaner) $140
2nd set is a pair of Solex singles with universal manifolds that fit all type 4 engines.
1.7-2.0 I have not run them and don't have all the linkage or air filters so what you see is what you get. I opened them up and they look OK no crud or corrosion.
Linkage sets are available on Flea bay but all that's needed are the pull rods.$65
