Grump
Feb 26 2014, 04:57 PM
I had to completely install all wiring in my roller since it was stripped for color change. The engine ran fine when pulled from donor. Was going to start it up yesterday but decided to test wiring first. Good thing since when I turn the key to the on position the fuel pump comes on. Not supposed to until it's in the cranking position. This is the same FI harness that was in the donor. I checked my wiring of the fuse panel, gauges, and switches and almost 100% certain they are correct. I even took all fuses out and has no effect. I did swap dual relay, fuel pump relay, voltage regulator board, and power supply relay. I spent 2 days trying to track this problem down, but am at a loss. I hope someone here can provide some help. Thanks... Bill
914itis
Feb 26 2014, 05:06 PM
Calling Timothy_nd28
He is the ljet resident expert. He will be here shortly .
timothy_nd28
Feb 26 2014, 05:18 PM
Any pics of this restoration?
You are correct, the fuel pump should not turn on by merely turning the key to the "on" position. Do you own a multi meter? If you were to pull the air flow meter connector off, does the fuel pump still activate when you turn the key to "on"?
Grump
Feb 26 2014, 06:02 PM
QUOTE(timothy_nd28 @ Feb 26 2014, 06:18 PM)
timothy was instrumental in getting the 1.8 running 2 months ago. When disconnecting the AFM, the pump does not come on. I replaced the ignition switch just to eliminate that as a problem. I disassembled all the wiring on the donor just to make notes, draw sketches and take photos to eliminate the guess work. Checked all my grounds and connections. I messed up somewhere but a re-check several times doesn't reveal any mistake. Electrical problems, as all who has had them can attest to, are a real pain. I do have a multi-meter and use if often. When I disconnected the AFM I put the meter on the fuel pump leads because I couldn't hear it even if it did run, which it didn't.
ClayPerrine
Feb 26 2014, 06:04 PM
There are two things that make a fuel pump run on the L-Jet system.
1. The air flow meter.
2. The cranking circuit.
The air flow meter turns on the fuel pump by energizing one of the coils in the double relay. There is a second coil in the same relay that is energized by the start circuit.
Check the engine harness connection to the relay board. There should be a short yellow wire with a female spade connector on it. Make sure that spade is connected to the right rear connector of the 4 pin connector block on the left rear of the relay board. If it is connected to one of the other connectors, it can cause the pump to run anytime the key is on.
FYI.... you do not need any relays on the relay board for the L-Jet system to work.
timothy_nd28
Feb 26 2014, 06:17 PM
I think you identified the problem. With the AFM connector pulled, the fuel pump stops (with ignition switch to on). It's possible that the AFM's flap isn't springing back to the zero position, which is causing the fuel pump contacts to remain engaged.
Reinstall the AFM's connector, turn the ignition switch to on. The fuel pump will be on (your original problem). Now, remove the AFM's black plastic cover.
Click to view attachmentLook at the red arrow. Are these 2 contacts touching each other?
Grump
Feb 26 2014, 06:27 PM
QUOTE(timothy_nd28 @ Feb 26 2014, 07:17 PM)
Hello. Just looked. Contacts are not touching.
Grump
Feb 26 2014, 06:33 PM
QUOTE(Grump @ Feb 26 2014, 07:27 PM)
I keep thinking it's something in the ignition circuit. The only new item since it ran last is it's a different 12 pin connector.
timothy_nd28
Feb 26 2014, 06:34 PM
Odd, you did say that when you pulled the AFM connector off, the fuel pump does quit? Pull the springy metal contact back slightly, increase the air gap. Is the pump still on when you manually pull it?
Grump
Feb 26 2014, 06:43 PM
QUOTE(timothy_nd28 @ Feb 26 2014, 07:34 PM)
Still runs. Sounds like it springs back to a metal stop. Contacts are open.
timothy_nd28
Feb 26 2014, 06:48 PM
With your multimeter, and the AFM connector pulled, measure the resistance between pin 36 and 39 on the AFM
Cap'n Krusty
I could be wrong, but I believe the FP is activated through the FP relay when the AFM flap moves off the stop. I KNOW there are more than one version of the double relay, and they DO NOT interchange. The VW unit is different from the Porsche one. Check the part numbers.
The Cap'n
Grump
Feb 26 2014, 07:03 PM
QUOTE(Cap'n Krusty @ Feb 26 2014, 07:48 PM)
The Cap'n
I put back on all the items that were on the last time she ran. If it worked then, it should work now, unless the squirrels gnawed on it.
timothy_nd28
Feb 26 2014, 07:19 PM
The dual relay is a pretty neat circuit. As Clay stated, this relay turns on the fuel pump when you turn the ignition key to the start position. As you release the key, (hopefully engine running) the voltage from the ignition switch is dropped, but the AFM contacts take over and keeps the dual relay energized, thus keeping the fuel pump engaged. It's a neat handoff between the AFM and the ignition switch.
You have an odd problem. When the key is just to the "on" position, your dual relay is being energized (it shouldn't be). We quickly isolated the issue by removing the connector to the air flow meter. With this connector removed, the fuel pump stops. This tells me that the AFM is somehow providing continuity between pins 36 and 39 on the AFM. Or pin 36 is getting 12volts somehow.
Grump
Feb 26 2014, 07:21 PM
QUOTE(timothy_nd28 @ Feb 26 2014, 08:19 PM)
Seems I can't find the pin number location diagram. I can't remember where I seen it.
timothy_nd28
Feb 26 2014, 07:41 PM
r_towle
Feb 26 2014, 07:44 PM
Sorry, but that is a totally stupid way to number anything.....
It has 7 pins..geez.
Have you though about a possible short circuit inside the wiring harness?
I might suggest that you follow the power from the pump, back to the source.
You may find it.
timothy_nd28
If it was a short in the harness, the pump would stay on if the connector was attached or detached from the AFM. Since pulling the connector off the AFM kills the pump, the short has to be inside the AFM. Well, that's where my moneys at
Grump
Feb 26 2014, 08:01 PM
QUOTE(timothy_nd28 @ Feb 26 2014, 08:48 PM)
No reading at all between 36 and 39. No voltage either. With the AFM cable detached and I turn the key on I hear a relay on the board click. Can't tell which one.
timothy_nd28
Feb 26 2014, 08:04 PM
You are measuring at the pins on the AFM?
Grump
Feb 26 2014, 08:14 PM
QUOTE(timothy_nd28 @ Feb 26 2014, 09:04 PM)
Cable and AFM. I read that when the AFM just opens, the resistance should go to zero. Maybe my meter stopped working in resistance mode. I'll try again tomorrow. Thanks guys..
Grump
Feb 27 2014, 04:45 PM
QUOTE(Grump @ Feb 26 2014, 09:14 PM)
To answer your questions timothy, yes there is 12v at pin 39, No resistance reading between 36 and 39. Showed no continuity. I was reading the tech manual and a article on the throttle switch. About 2 weeks ago I replaced the throttle cable and had to open the throttle some to get the new cable to attach to the pin. I disconnected the cable and let the throttle return to its stop. I then turned the key on and no fuel pump. It did come on during cranking as it should. I did this several time to verify. I took off pedal board to get some more slack at the pedal. Turned key to on... pump started running again. Same problem as yesterday. Why did it work for a brief period.. Anyway took reading on the dual relay. All okay except 88d, which showed 12v on the on position. It should show voltage only when cranking. Back to square one. Sorry this is so long...
timothy_nd28
Feb 27 2014, 06:44 PM
Are these readings from the AFM or the AFM connector on the FI harness? If you are reading from the AFM connector (wiring harness), you should have 12 volts on pin 39 (ignition key set to on). But I need to know what the resistance is directly at the AFM between pin 36 and 39 (connector off).
Grump
Feb 27 2014, 07:25 PM
QUOTE(timothy_nd28 @ Feb 27 2014, 07:44 PM)
No reading at all between 36 and 39 at AFM.
Grump
Feb 27 2014, 07:27 PM
QUOTE(Grump @ Feb 27 2014, 08:25 PM)
When you disconnect AFM. the pump comes on in crank mode as it should.
timothy_nd28
Feb 27 2014, 07:33 PM
New piece of info, didn't know that. I'm studying for an exam tomorrow, won't be much help tonight. If you can wait, I can walk you thru some tests to do tomorrow. If you can, post a few pics of your set up. A pic of your dual relay and your AFM would be great.
Grump
Feb 27 2014, 07:39 PM
QUOTE(timothy_nd28 @ Feb 27 2014, 08:33 PM)
Okay, that's fine. good luck with exam..
Grump
Feb 28 2014, 01:27 PM
timothy_nd28.. I screwed up. When you asked about the AFM contacts being open, I must of been looking at the wrong point. Today I went over that diagram again and indeed the contacts were closed when the AFM was closed. I have a corroded AFM and looking at that, the contacts were open. I bent the rod just a fraction to open the contacts. After installing AFM, it worked as it should except the fuel pump didn't come on when AFM manually opened. I installed an old dual relay and all appears to be working as it should, the pump comes on when AFM opened. I cleaned and sealed the gas tank with the por15 kit a week ago so I'll get some gas and hopefully fire it up. I should of looked closer at your photo..I hope you did well on your exam..
timothy_nd28
Feb 28 2014, 01:43 PM
Awesome
I knew we were on the right path, but was getting ready to pull my hair out earlier!
If your AFM is corroded, (I presume from the cover being off) you should consider replacing it. The resistor plate embedded inside the AFM could be compromised from the damage. This will cause your car to have a incorrect fuel map.
Grump
Feb 28 2014, 02:30 PM
I have 2 of most items. The AFM in use is off the running engine. The spare is off the roller, and that is the corroded one. Trying to put one together from 2, (1 rusted but running and complete, 1 good body but stripped) is somewhat of a challenge. I took every item off the donor so I would know how to assemble the bare roller. I spent a lot of time waiting for new parts or good used ones, that were either missing or not usable. How this rod got bent or miss-adjusted is beyond me. It worked when I put it on a shelf a month ago. I must of mistakenly thought that the rod was part of the relay when in fact it held the relay open. Thanks again.
