Hey all,
Gathering suspension parts for my track car and I'm trying to make up my mind
I'd like to go with yellow adj. Koni's.
Does anybody now up to what spring rate the yellow Koni's can handle?
Should I go for torsion bars (22 or 23mm)
I can have the struts modified for coilovers for about the same money I'd need to spend on the t-bars
Coil over springs are pretty cheap and I wouldn't be stuck with just one spring rate
Any info on springrates in relation to the weight of the car?
I'm aiming for about 1750# for the car and was thinking about starting with 275 or 300# rear springs
Does anybody know the spring rates for the front torsion bars?
I've been looking into it, but different sources quote (very) different rates
Anybody running big front t-bars (22 or 23mm), what springs are you using in the rear?
I know, lots of questions, but I'm trying to figure out my options, so any advise is welcome
Right now I'm looking at too many unknowns to make a decent guestimate
thanks...
Jeroen
