Parts from 222:
Oil cooler and radiator – front mounted, stainless steel braded lines and fittings all the way to the rear firewall - $450 (note: Those crap black wrapped lines were replace with Stainless Steel braided lines). SOLD
This picture will give you an idea of the size of the radiator and cover. Taken during the cage fabrication project.
Large Accusump with automatic valve – stainless steel lines and fittings - $250 Sold
Gunther screen – fiberglass - $200
Trailer – dual axle, one axle with brakes, all new trailer tires, lockable tire rack, mounts for air tank/large tank for nitrogen (comes with tank), light weight ramps, aluminum trailer box, custom air deflector and a winch - $2,500
Steering quickner, including all mounting brackets and top (very expensive U joint) - $200 Sold
Front bumper and splitter - $225 SOLD
Foley reinforced trailing arms with needle bearings with grease fittings - $700 pair
Light weight batteries – Interstate - about 11lbs - (2) each - $100 for the pair
15” Gotti wheels – (4) each. Two are 8”, two are 11”. 8” wheels are polished, 11” wheels are matt finish. Very light - $1,200
Gotti wheels parts – Have enough 15” parts to build a variety of front or rear wheels. Everything goes for $1,200.
A15 compound Avon slicks – Two are 8.7”x21.5” x 15”, two are 10.5”x23.0”x15”. 75% tire remaining/ run less than 40 minutes - $700 set ($1,600 new)
Halon fire extinguisher and mounting bracket – Scca approved - $75 SOLD SOLD
5 point Schroth belts – two sets, one brand new never installed - $175 SOLD
Kirkey intermediate race seat with cover - $200
Modified stock seat with large bolsters - $200
New Bosch Alternator – never installed - $85
Tilton starter (2) – First one was just refurbished by factory distributor, Second is having drive gear replaced - $250 each
Koni shocks (4) – Yellow adjustable, rears with 240# Eibach springs and adjustable perches -$450 REARS SOLD. Fronts still available at $225
8” and 10” Eibach springs - 10” coil over springs (pairs) in 400, 350, 300 and 225 weights. 8” (pair) in 225. The 400, 350 & 300 springs are new. $42.50 each. All Springs SOLD
Engine Bar – 914-4 with new mounts - $85
Alum. pedal board – brand new, never installed - $75 Sold
Shift rods – two with alum. Coupler, one without the coupler - $35 ea One alu with coupler SOLD
JWest Engineering Shifter - $250 SOLD
Reverse lockout - $30 Not for sale
350mm Momo steering wheel with quick disconnect- $125 SOLD SOLD SOLD
Sorry folks, but I forgot I took the Momo wheel off, sold it and bought the brand new steering wheel in the picture.
Ahhh. Now I can't upload the picture. Will have to do it in a reply.
The chassis is advertised over in that section of the classified section.
All parts FOB Los Altos
