Hi guys,
today i fired up the spare engine. Makes a strange sound like tac tac tac.
Anybody knows what it could be? Think it comes from the right head. Valves are fresh adjusted.
Videofile
QUOTE (michelko @ Jan 8 2005, 09:21 AM) |
i will check that stupid valves again |
QUOTE (jr91472 @ Jan 8 2005, 09:09 AM) |
Is it true that over time as the valves get "out of adjustment" that they actually get tighter? not looser? |
QUOTE (SirAndy @ Jan 8 2005, 11:09 AM) | ||
that doesn't sound good ... rod-knock? i had an engine that sounded similar after it lost a rod-bearing ... Andy |
QUOTE (Root_Werks @ Jan 8 2005, 09:03 AM) |
I dunno man, it sure sounds like valve lash to me. It gets quieter as the engine warms up. Plus, when you give it a little throttle, I don't hear anything. So I don't think you have a bad wrist pin or rod knock etc. Those stick out like a soar thumb when you bump the throttle. .015, dang, I am at work right now and can't remember the conversion. Is that .006"? Most people I know do .006 across the board, but if you live in a cooler climate, I would go .004 intake and .006 exhaust. Pop off a valve cover and check the #1 again. Maybe it is the rockers? It is valve train noise for sure though. I have heard that a bazilion times. Other than that, motor sounds great! |
QUOTE (newdeal2 @ Jan 9 2005, 11:38 AM) | ||
Sounds a little like my engine as it's warming up. I recently adjusted my exhaust valves to .008 and that's what they sound like. It does quite down quite a bit when warm/accelerating. I assume this is a fresh rebuild? |
