I'm in the process of installing a 2.7 -6 in my white car. Was planning on moving the fuel pump to the front trunk to avoid the vapor lock problem I experienced on my trip last year. But with the CIS system requiring a 150 psi fuel pump, I'm not sure I want that high of pressure running through the car.
Even if I did put it in the front, should I change the SS pressure line to a threaded fitting line, or mount the pump on the firewall in the engine bay?
What have others done?
Thanks,
Jeff
