QUOTE(JawjaPorsche @ Apr 10 2014, 09:33 AM)
QUOTE(Steve_R @ Apr 10 2014, 09:25 AM)
Are you talking about this light?
Pelican Parts has them for $8.50 in the interior section.
No, that is not the original light.
The one you mention has to have some modifications to fit. Plus the blub is extremely close to lens when on which can cause melting. I got one and it looks okay but it is not the original light. I never turn it on but I can.
Here are reviews on the light on Pelican Parts. Note: This is NOT a knock on Pelican Parts. This is the only light available.
914 Interior Light Fit
By Kevin B., submitted February 28, 2014
Comments: To get the 3 terminal connections, I used pliers and vice grips to bend the metal parts to effectively create a ground tab. So my implementation still allows me to turn on the light when doors are shut. Also had to bend the latch so its notch was further back, so it engages with the upholstery edge. Careful: It's easy to snap these metal parts.
Interior Light for a 914
By Chuck G., submitted March 29, 2013
Comments: This part was not up to the fit quality i would have expected. the latching mechanism on the side that is stable was too short as was the metal latch that is movable to permit bulb replacement. Consequently, the fixture kept popping out of the hole in between the seat. In addition there were only 2 of the 3 original terminal connections provided for on the replacement part. This wasn't nearly as bad as the fitment, as I could get along without being able to turn the lamp on from the switch with the door closed. I wound up Super gluing my original fixture and re-using it.
Followup from the Pelican Staff: Yes, unfortunately, the replacement VW-style lamps have been this way for about 10 years now. The newer ones have a slightly different shape that doesn't fit super-well into the middle of the seats. You can use some tape on the edges to make it thicker, and then it will fit much better.
914 Interior lamp: Careful, double-check the connector fit
By haasman, submitted February 10, 2009
Comments: Ordered this for a 1970 914-6. Surprised that the two + terminals on the light were larger than the connectors in the car. Either the light or the car wiring would need to be modified to fit.
