e_artiles
Mar 12 2014, 07:35 PM
The PO had the outside door handles media blasted, to remove the chrome, and powder coated them black. Time has worn down the powder coating to the base metal. Otherwise, they are in perfect working condition. Can they be re-chromed or should I try to find a new set?
r_towle
Mar 12 2014, 07:59 PM
Try an ad in the classifieds for a used set.
e_artiles
Mar 13 2014, 10:50 AM
I know that's the probable final solution. No input on possible re-charming? Has anyone attempted it?
ConeDodger
Mar 13 2014, 11:03 AM
Why would you not be able to rechrome them? Powdercoating is melted powdered paint. Remove it and bring them to a plating shop.
The previous poster is just pointing out that you can probably easily find used ones and swap in your locks.
Socalandy
Mar 13 2014, 11:44 AM
The handles are pot metal and if left in the striping tank to long the threads will start to melt away. Tell the chrome shop their pot metal !!! Also, there will be a build up of chrome on the hinge points and back that may need attention to have it work smoothly after the process. This was my experience anyway
URY914
Mar 13 2014, 12:22 PM
You'll have to disassemble them before you do anything. Be VERY careful then taking the hinge pins out. If you crack or break anything on the flapper they are toast.
e_artiles
Mar 13 2014, 02:15 PM
Thanks for all the great input...this site has a wealth of knowledge! I will look for replacements and hold on to the originals as a last resort.
