Ken6432
Mar 16 2014, 10:06 AM
I have a '74 with a 2.2L 4 that uses Weber carburetors. The throttle cable is very sticky, making the throttle pedal very had to push. I am pretty sure it is the cable causing the drag and not the linkage. What is the best way to lube the cable?
Thanks,
Ken
tomeric914
Mar 16 2014, 10:52 AM
Might be the pedal itself, available new from Pelican.
Might also be a broken throttle cable tube.
Michael RD
Mar 16 2014, 11:06 AM
Most motorcycle shops sell a small cable lube like clamp. It has a split rubber sleve or grommit in it with a small port on the side for spray can mosquito noses. They are priceless for doing alot of diffrent cables.
Mike Bellis
Mar 16 2014, 01:03 PM
If your cable is sticky, it is time to replace it. Use a dry graphite lube.
Wet lube will attract dirt over time.
Cap'n Krusty
Mar 16 2014, 01:28 PM
Disconnect the cable from the linkage, get a friend to put a "little" tension on the end and work the pedal up and down. If the cable is the problem, it'll be obvious. IME, it's usually NOT the problem.
The Cap'n
