So, I'm in the process of installing an MSD 6200 on my car.
Obviously, the first thing I did was to read everything I could on the forum about these installations.
I am aware of the possible tach issue and will address it at the end.
One thing that caught my attention if the fact that the 2 big wires (red and black) are directly connected to the battery. I didn't see anyone put or mention the installation of an in line fuse.
Shouldn't this be protected somehow or is there already something in the box in that regard?
I intend to use Magnecor 45442 wires but I don't know if they come with the proper grommets to seal around the cooling tin.
Another concern I have is that my Blaster 2 coil is supposed to be mounted vertically because it's oil filled. The only area I could see would be on the firewall which will place it too far for the coil to distributor wire to reach.
The other coil alternative is the vibration model that can be mounted in any orientation and could then be placed in the original location. Anyone has comments on that coil?
