All right boys and girls,
Just finished rebuilding several sets of Webers and I know there are a few of you here looking for some to get your project up and running. I put these packages together based on what application I thought each would work best with. I'd like to try to keep them together as pictured, but I understand each of you will have your own needs and applications, so I'll split them up but let each buyer know what additional components may be necessary to complete their installation. Sorry in advance for the crappy pictures and I can provide more if needed. Everything was a little cleaner before I started moving things around with my dirty hands.
Buyer pays shipping and Paypal fees if necessary. All proceeds go towards the down payment on our first home next month!
First set: 40 IDFs - $550
Complete with hex bar linkage, but missing carb tops which can be purchased from CB Performance. Air filters are used but have been cleaned and degreased. If you stick with the Hex Bar linkage, I am not positive that these air cleaner bases are the correct ones for our Type IV engines. I think that the CB hex bar linkage needs an offset-style air filter base in order to maintain the correct geometry, which can be ordered directly from them. Otherwise they are complete with velocity stacks and the longer intakes pictured. Note: these were rebuilt, then installed on my car (with different jets) for about 3 months. I removed them this past weekend and drained them of fuel. Recommended for a street driven car under 2.0 liter displacement or smaller.
Main chokes: 28mm
Main jets: 120
Idle jets: 50
Emulsion tubes: F11
Air correction jets: 200
