The captain makes a good point here, in that most cases where you have mysteriously lost a stud will be due to the boss being jacked up (the other case being if you used those stupid copper lock nuts that will always pull the stud if you try and remove them! BTDT)
Never forget this engine is almost all VW. In the case your stud boss is jacked up, this has been my source for the step studs:
www.airheadparts.com
part number:
N146841 - Stud, 8x9x56
at 9 bucks a pop they are not exactly cheap for a stud, but it is worth it to try as 9 bucks is a lot cheaper then pulling and rebuilding your heads!
QUOTE(Cap'n Krusty @ Mar 19 2014, 08:16 PM)
Late to the party here. In nearly every case where an exhaust stud has fallen out of a 914, the threads are less than optimal or the boss is cracked, or both. Look carefully! You cannot make a satisfactory exhaust stud out of all thread! The stud you need is 56mm long. The dealer can get them for you, but it makes absolutely NO sense for them to stock parts for a car approaching 40 years old. It should be noted that most, if not all, the aftermarket sources get their dealer specific parts from, wait for it .................., THE DEALER! You can, too, and may even get a better price if you're a PCA member.
The Cap'n
