Left side came unbolted like a dream, but all four nuts on the right side are stripped.
I hit them with Liquid Wrench, then tried vice grips and don't get good enough bite and channel locks with same result.
Anyone care to share ideas.
Thanks
QUOTE (mikez @ Jan 10 2005, 09:44 AM) |
Use your BIG 3/4 breaker bar, a short extension between the socket and bar, and then slide a pipe cheater bar on the end........set at 9 o'clock, and give it good jump.....depending on the last time it was removed you will here a sharp crack..... |
