Mueller
Jan 10 2005, 01:26 PM
I put chrome '74 bumpers on my '73 car over the weekend, I like the "no bumperette": look, however the bumpers are tweaked right behind the bumperettes and I don't think they can be pounded out and still look decent
upon looking at the bumpers, i think a good comprimise would be smaller bumperettes...maybe something that would be flush with the top rubber pad.....
the biggest challange will be to keep the surface of bumperettes looking decent once the material was cut off.....any ideas on how to make the new surface look okay and how to remove the saw marks in the rubber?
GWN7
Jan 10 2005, 01:36 PM
If the bumper is tweeked, you can try pressing it back. Put soft pine board on the good side and a harder piece of wood on the press side. I did this to the bumper on my motor home and it turned out ok.
As to the bumperettes....I could cast a mold of just the portion you wanted and insert new mounting bolts in it........
Mueller
Jan 10 2005, 01:41 PM
I'd be interested in new ones made shorter...not too sure if they would be interchangable from the front and rear or not......I do know that they are totally different side to side....
I did an okay job straightening the bumpers out, but they are not perfect and the bumperettes do a good job of covering up the area...
BIGKAT_83
Jan 10 2005, 01:49 PM
I just removed the small bumperettes from a set of 76 big bumpers, and plan to use these on a set of early chrome bumpers instead of the larger bumperettes.
neo914-6
Jan 10 2005, 02:07 PM
Mike,
I have been mulling this over too. Have you looked at adapting Boxster or 9xx bumperettes? They may just be a cap over a shock but the shapes are nice.
URY914
Jan 10 2005, 02:10 PM
I believe this is called "breast augmentation" in the medical field.
ClayPerrine
Jan 10 2005, 02:21 PM
QUOTE (URY914 @ Jan 10 2005, 02:10 PM) |
I believe this is called "breast augmentation" in the medical field. |
I think that you have that backward.. This would be "breast recuction".
Leave it to Mueller to want to reduce the size of a breast.....
Root_Werks
Jan 10 2005, 02:39 PM
Couldn't you use the little ones you see on some 928's? Or even 993's?
Aaron Cox
Jan 10 2005, 03:22 PM
QUOTE (BIGKAT_83 @ Jan 10 2005, 12:49 PM) |
I just removed the small bumperettes from a set of 76 big bumpers, and plan to use these on a set of early chrome bumpers instead of the larger bumperettes. |
elliot cannon has these on a 73/74 bumper!
Mueller
Jan 10 2005, 03:27 PM
QUOTE |
elliot cannon has these on a 73/74 bumper! |
show us a picture numbnutz
ClayPerrine
Jan 10 2005, 03:34 PM
Aaron Cox
Jan 10 2005, 03:42 PM
QUOTE (Mueller @ Jan 10 2005, 02:27 PM) |
QUOTE | elliot cannon has these on a 73/74 bumper! |
show us a picture numbnutz |
am i elliot cannon? didnt think so .... numbnutz
John
Jan 10 2005, 03:53 PM
Where were you guys when I asked about backdating my bumpers?
This is good stuff, however, now you are making me want to see bumperette reduction to decide if I should keep my 74 bumpers or go with the bumperetteless early bumpers.....
I guess I'll wait and see if someone decides to make reduced bumperettes for the 74 bumpers....
In the mean time, I like the look of the clean bumpers.
