xsboost90
Jan 10 2005, 02:40 PM
does the ebrake and brake line go on the top or bottom of the rear swingarm??Theyve been off so long ive forgotten!
skline
Jan 10 2005, 02:43 PM
You have got to be kidding. Set them on the ground and look at them. It should be obvious which one goes on which side. Look where the wheel will be and that should help you. If all else fails, the ebrake holder goes on the bottom.
xsboost90
Jan 10 2005, 02:46 PM
well i have all of the brakets etc off of them so they are almost identical except the brakets for the lines. I thought those went on the bottom, just making sure. Hate to have to take it all back apart after assembly. THanks.
Root_Werks
QUOTE (skline @ Jan 10 2005, 12:43 PM) |
You have got to be kidding. Set them on the ground and look at them. It should be obvious which one goes on which side. Look where the wheel will be and that should help you. If all else fails, the ebrake holder goes on the bottom. |
e-brake holder on bottom. Oh, and I hope you painted them yellow, it's faster you know.
bondo
Jan 10 2005, 03:58 PM
QUOTE (Root_Werks @ Jan 10 2005, 01:46 PM) |
e-brake holder on bottom. Oh, and I hope you painted them yellow, it's faster you know. |
Don't do that unless the rest of your car is yellow.. You don't want your suspension parts to be passing you!
airsix
Jan 10 2005, 05:10 PM
I know all about yellow. I want to know which color weighs the least.
-Ben M.
xsboost90
Jan 10 2005, 05:42 PM
painted them gloss black, i was thinking yellow but then i remembered back to the future- nobody calls me yellow.
