QUOTE(jim_hoyland @ Mar 28 2014, 09:03 AM)
OK, sounds good. Last question; can the rod be adjusted when both MC and pedal cluster are installed ?
jim, glad you asked these question, because as i just finished replacing my MC, i had not even considered the need to adjust or set the depth of travel etc of the rod on the pedal cluster. I have a rebuild cluster that i was thinking of putting in, but the old one seems fine, so i probably dont have to make and adjustment since i did not change it yet, but at some point i will. I guess i should not assume the last person that messed with it had it adjusted correctly, so that leads to the question, how do i know it is set right and pressing in the piston fully or properly?
