QUOTE(76-914 @ Mar 29 2014, 08:28 PM)
I made the style your not interested in but it varies with the type of steel. DOM vs. Chromoly are apples to oranges. + Chromoly is a bitch to bend but less weight.
Sorry, I have to comment since this is one of my pet peeves...
In this application there is really no strutural reason to use chromoly over mild steel. For an engine cradle you need a stiff, non-yielding structure. The modulus of elasticity (stiffness) for mild and chromoly steels are very similar (205 GPa for 4130 chromoly and 200 GPa for 1020 mild) which means that for similar geometry, the structures will be equally stiff and weigh the same.
The difference comes in when looking at ultimate strengths; 670GPa for 4130 chromoly and 394 GPa for 1020 mild. This means that once the structure has yielded the chromoly will take more stress to break. You'll never reach this in an engine cradle. Note that if not properly normalized, welded chromoly is more brittle than welded carbon steel and will fatigue crack more readily when cyclically fatigued.
That's the end of my soapbox rant.
In regards to your question, stiffness/strength increases as a cubed quartic function of size. This means that it's always better to go with a larger OD tube and smaller wall thickness when you are looking for stiffness with minimal weight. 3 ga steel is way thicker than necessary, 3d914's tube sizes should be just fine in your application. That said, I would be tempted to go to a 1.5" or larger tube with smaller wall thickness, say 1.5x0.095", which would theoretically be 3.6 times stiffer while only 80% of the weight.
