ewdysar
Jan 10 2005, 06:12 PM
My car feels kinda like it's getting small steering inputs from the rear while freeway cruising on smooth and level stretches. I'm figuring that it's the trailing arm bushings (probably original). I guess it could also be a twitchy alignment, or just me getting used to a real sports car again.
How can I check the TA bushings for play without major disassembly? If they're bad, I'm probably going with Mueller bearings.
Mueller, where are the rear bearings available? I checked them out once with a link in your signature file, but that link's gone now...
Thanks,
Eric
SLITS
Jan 10 2005, 06:16 PM
On a lift, push to and fro on the tire........you will see the TA moving at it's piviot point.
Aaron Cox
Jan 10 2005, 06:24 PM
what doofmeiester says
jack up the side of the car... pus and pull on the trainling arm. i had the same issue..dead bushings.
look for ovaled suspension ears too
Mueller
Jan 10 2005, 06:48 PM
I'm out of stock right now....Tarett Engineering has some in stock
if the bushings are that bad, you should be able to jack the car up and check by grabbing the end of the t/a and shaking it....
Aaron Cox
Jan 10 2005, 06:58 PM
call me on an effin typo...
project is ok...
Twystd1
Jan 10 2005, 07:17 PM
Where do you buy effin typo's???
Do I need them on my car like you guys to go fast????
Do they come in chrome?
Does Tarret sell em?
And do I have to shake my tires to see if I have bad ones?
Twystd1
