The basics...
'76 2.0 mostly stock in a '73. ERG and air injection is removed. 1.7/1.8 exhaust with 4-1 collector and glass pack muffler. Yeah, it's a bit loud.
It was running pretty well after warm-up. I swapped out the "trigger points" for a spare I have, to see if it would help the warm up roughness. It did not. The timing is off a touch from removing and reinstalling the dizzy. I did replace it very close to where it was with the intention of resetting the timing.
This is where it started popping out the exhaust. Not terrible, but still.
I replaced the original Trigger points and it's still doing it. I don't remember it doing this before, even with the timing a bit off.
I would like to fix it before sustaining 3500 RPM while setting the timing correctly. As I up the revs it gets worse. I don't like the sound of it.
So... What did I mess up while I was at it?
Thanks,
Bob
