QUOTE(ww914 @ Mar 31 2014, 02:18 PM)
I am in the process of determining why I don't have potential to my heater blower motor. I know the motor works because I hot-wired it to test it. Using the Haynes manual electrical diagram, I have traced all the wires (I think) and where they go on the relay board, the blower lever and checked the fuse on the fuse block under the dash. The diagram shows S13 as a fuse on the regulator panel. Anyone know where this fuse is located? If you look closely at the schematic it shows that connection T14/14 is north of the fuse, which tells me that the fuse must be somewhere on the relay board. Any help on this would be greatly appreciated.
Well guys, I would never rat on someone else, but since it is me, here goes:
When I thought the problem was electrical gremlins and the problem simply could not be fixed, the magic light came on. I had the relay in the wrong hole. Geez, it works good when the 'lectric flows where its suppose to.
