Hi!
I'm trying to replace the old brake hoses with new ones, but the fittings on the ends of the old ones are "frozen" onto the hard lines. I've been hitting them with penetrating oil for the past few days, and am hoping that does the trick . . . but if it doesn't then what? I definitely don't want to booger up the hard lines.
I know that "wiggling" the nut (loosen, then tighten, then loosen, rinse repeat) will sometimes help; heard that tapping might too--but if these don't work, can I use heat? I'm thinking maybe a small propane torch with the flame directed on rubber hoses' fittings and a heat sink on the hard line.
I'd really appreciate any insights, BTDTs, pitfalls, watch-outs, etc.
Thanks in advance!
All the best,
Steve A-
