Hi everyone. I am new to the forum. Just got a 1973 914 1.7... I have a number of issues I wanted to discuss. Not sure what to begin with. First I am including a pic of the car and also a pic from the inside looking at the location where pedals would be (they are removed right now. Here are a few questions i have right away.
1. need to get a master cylinder. Looking at ebay I see they range from $80 to $400. some are ATE some FTE others are just remakes. Not sure how important it is to get a OEM part or will an $80 part do?
2. If you look at the picture you will see a gaping hole right under where the gas pedal and the whole pedal assembly is. Any thoughts on how to fix it. I looked under the car and there seems to be a bracket support there as well. What is that bracket called and thoughts on best way to fix the hole.
3. i tried removing the fuel tank but had no luck it seems to be very difficult to get out. Am i missing something? Is there a trick?
Lets start there. Any help is greatly appreciated and please allow for the newbie factor...
