On my 74 2.0L, I still feel that I am experiencing engine oil temps that get too high. For example, in San Ramon, CA yesterday it was in the 70's I believe.
On a short 15 minute drive on the highway, my oil temps got up to just under 220 on a VDO gauge. Yes, these gauges are not perfect, but the only measuring stick I have at the moment. In the past, the things I have done:
1. Adjusted valves
2. Adjusted timing to 27 degrees at 3500 RPM
3. Complete oil change
4. Sprayed some brake cleaner up into the oil cooler from below and blew out with compressed air.
5. Thermostat and flaps operating correctly (new thermostat cable installed last weekend).
6. Plastic flaps are there hanging under the body at the firewall.
In the 914 oil flow diagram, there is an oil pressure relief valve that is supposed to close as the engine oil warms up. Do these ever fail? Or sort of fail such that they never get to position "c" in the diagram below?
