QUOTE(smarens @ Apr 8 2014, 06:52 PM)
better not wait long, there is only 2 available
Actually I just did more up there are at least 10. I don't always get the inventory on the site updated, but stock should not be an issue. Just a little heads up I do die cit these with hole locations on the bottom. There is some variation, but they are pretty close so you should not have to pull the vinyl up to find the holes.
There is also relief cut to lay down the back corner and for the top section of the sails.
No one else does this. And yes not identical to OEM, but nice material that will stand up to the weather.
