When I pressed the clutch in to start my car (2000 subaru outback 2.5L w/ 5 speed) it went almost all the way to the floor but I was still able to shift (only about 1 inch of travel at the bottom of the pedal travel had any resistance even though the pedal returned fully). When it did have resistance the pedal felt normal and the resistance did not slowly build, it occurred suddenly. After about 30 shifts the problem fixed itself, so I checked when I got home. Fluid is at the Full mark and no obvious leaks.
Car has 210,000 miles and I think it's the original clutch so there is a decent amount of wear on everything. I replaced the MC to slave cylinder line a few years back because it sprung a leak.
Only thing I can think of is the clutch MC seals are wearing out or there is some debris in there. Just seemed odd for it to fix itself, I'm guessing it will come back soon.
Andy
