KaptKaos
Apr 12 2014, 09:57 PM
I am getting a back fire on deceleration. I can replicate the back fire fairly reliably, and avoid it as well. I am hoping this may help provide some hints as to where to look.
The car is a 1.8 running 40idf carbs, with an unknown spec carb cam. It has been running great for nearly the last two years until this started. Ignition is a SVDA dizzy with a pertronix.
I have cleaned all plugs. They were all in nice shape, without carbon build up.
I have tightened all intake and exhaust nuts/bolts. I have examined the exhaust for leaks or holes, and have found none.
Valves adjusted about 1,000 miles ago.
If I take my foot off the gas, and leave the car in gear allowing it to slow, I will get a back fire almost every time.
If I take my foot off the gas, put the car into neutral and use the brakes to slow the car, I will not get a back fire.
Assuming that there are no leaks, and the the timing is good, where should I look? How do I tell where the problem may be.
brant
Apr 12 2014, 10:33 PM
sounds like an exhaust leak...
KaptKaos
Apr 12 2014, 10:51 PM
QUOTE(brant @ Apr 12 2014, 09:33 PM)
I thought so too, but I have tightened everything up, both when cold and when hot.
Bob L.
Apr 12 2014, 11:10 PM
Similar problem here. I keep tightening 3 & 4 but they wont stay. Is it OK to torque them when hot?
I'm thinking locking nuts, like "Stage8"
Elliot Cannon
Timing? Sometimes you can have an exhaust leak and not be able to tell right away. If you look under the car while the engine is running at idle and have someone block the exhaust with a rag or piece of cardboard or something you might be able to find something. It isn't always easily identified.
KaptKaos
Apr 12 2014, 11:13 PM
QUOTE(Elliot Cannon @ Apr 12 2014, 10:10 PM)
Timing?
If it were running differently, but its not at all. That's why I mentioned the dizzy and the electronics. No Dwell or points to deal with.
euro911
Apr 13 2014, 01:56 AM
QUOTE(Elliot Cannon @ Apr 12 2014, 09:10 PM)
All one really needs is a stethoscope or a length of hose to find where an exhaust is leaking. Having a lift is a plus
monkeyboy
Apr 15 2014, 08:43 AM
Backfires on decel can also be lean idle jets, or possibly a clogged one.
era vulgaris
Apr 15 2014, 09:09 AM
I'm not sure if the 1.8 deceleration valve is plumbed the same as on the 1.7, but when I got my car it would consistently backfire when I let off the throttle above 3000rpm and stayed in gear. Likewise, if I simply went into neutral and braked, it didn't backfire.
The problem on my car was that some idiot (scotty boy?) had unplugged the front-most vacuum hose of the deceleration valve, that plugs into the plenum. Then left that hose sitting disconnected on top of the engine, and plugged the port on the plenum. Once I reconnected the hose the problem went away.
I'm sure your hose is probably still connected, but it's possible you might have a leak around that hose.
Edit: scratch that! Nevermind, just noticed you said you're running carbs.
euro911
Apr 15 2014, 12:19 PM
Joe's running carbs. It's more than likely exhaust related ... it has a history of exhaust leaks
Bring it to shop class tonight
r_towle
Apr 15 2014, 01:54 PM
take a small piece of 2*4 and after the car is running, lay on the floor and hold the piece of wood flat on the end of the tailpipe.
Seal the tailpipe so nothing can escape.
If you have a leak, you will have a much easier time finding it using this method.
rich
KaptKaos
Apr 16 2014, 02:49 PM
QUOTE(r_towle @ Apr 15 2014, 12:54 PM)
rich
I'll try that Rich. Thanks for the tip.
KaptKaos
QUOTE(euro911 @ Apr 15 2014, 11:19 AM)
Shop was cancelled till next week. Did you get the message?
euro911
Apr 16 2014, 04:17 PM
No. I didn't make it anyhow ... stayed at the shop to crate up a motor
