Spoke
Jan 12 2005, 07:07 PM
I'm changing a ball joint on my 914 and can't figure out how to remove the nut with the 4 notches. Do I need a special tool to do this? How about a big pipe wrench or channel lock?
I used liquid wrench on it for a couple of days now. How to remove this sucker? The Star lock piece has been removed.
Thanks,
Spoke
Series9
Jan 12 2005, 07:11 PM
There's a special tool that costs about $40.
The following constitutes chopstick advice:
I have removed them several times with an air hammer stuck in one of the notches pointing in the counter clockwise direction.
Series9
Jan 12 2005, 07:14 PM
jim912928
Jan 12 2005, 08:03 PM
I bought the tool...took the arms to a friends with an impact wrench and zzt zzt they were off. I first tried with that tool and a breaker bar...no dice.
Kerrys914
Jan 12 2005, 08:11 PM
Dr Evil
Jan 12 2005, 08:29 PM
I bought that tool from Pelican and it stripped on the first try. The metal was a type that was weaker than the nut. Kinda dumb.
I ended up using a pipe wrench and it worked great. Replace the nuts ($14 ea) and use anti-sieze on the threads. You'll thank yourself later.
If it wont budge with a wrench you can try a drift and hammer in one of the grooves, or cutting with a dremel (I had to do this on one, not fun at all). Its like splitting any other nut.
Spoke
Jan 16 2005, 07:38 AM
The pipe wrench worked!
I used the top half of my floor jack's pump arm as an extension. Also used liquid wrench and some heat from a propane torch to finally loosen the nut.
Thanks for the help!
Spoke
