PanelBilly
Apr 20 2014, 10:02 PM
If I mount the MSD on the firewall behind the driver, do I need to worry about it being in the way of the rainhats? Just tiring to get everything ready for the engine.
Mike D.
Apr 20 2014, 10:24 PM
No, that is exactly where mine is mounted. MSD6al mounted vertically behind driver. Put the engine in first then mount the msd where there is room.
john77
Apr 20 2014, 10:25 PM
Mine has plenty of room right behind the driver. My MSD's bolted to a plate attached to the battery tray, so it faces the back of the passenger seat sandwiched between the battery and the firewall.
tomeric914
Apr 21 2014, 10:35 AM
PB, I mounted my MSD on the trunk away from the engine. IIRC, it doesn't interfere with anything in the trunk and I can still put the targa back there. Not sure if it shows on my build thread or not. Drop me a PM and I'll get some pics if it isn't.
Tom
Apr 21 2014, 07:49 PM
tomeric914,
From that, I guess the orange and black wires in the sheath from the MSD to the coil can be a good distance away with no issues?
Tom
tomeric914
Apr 22 2014, 06:28 AM
QUOTE(Tom @ Apr 21 2014, 08:49 PM)
As long as the black and orange aren't extended farther than the factory MSD harness then you should not have any issues.
campbellcj
Apr 23 2014, 04:18 PM
^^^ Same here, MSD boxes are in the rear trunk w/ no problems.
iamchappy
Apr 23 2014, 04:29 PM
Should have no problems with a firewall mount if mounted high and on drivers side.
It's where i mounted mine, different intake setup
but i think you can see.
