This is the last of the 914 parts I really need to get rid of.
Brand new 6 spring sachs Hi performance clutch $50.00
All of the hard to find heater stuff is great shape. all POR15 coated Clear and or black 75.00
Poly front a arm bushing with grease fittings. Used but only about 20 AX runs. fitted for butter smooth movement. 25.00
21MM Sway away Torsion bars, 50.00
Early ball joints again about 20 AX runs 30.00 (still on a-arms) will remove or ship as whole.
adjustable rear brake bias valve direct replacement of stock piece. 20.00
