QUOTE(Mueller @ Jun 3 2015, 04:32 PM)
Bummer, my lathe only has a 13" diameter clearance....
I was actually considering doing it myself with a spare trailing arm, rear spindle & bearing (all of which I have extras).
Then welding up a simple jig on the benchtop to hold a grinder with cutoff wheel (small steel chopsaw head would work better).
Then you just rotate the wheel while pressing the cutter against it.
There are many youtube videos showing people that are very "redneck" looking in their methods that get great results.
EDIT - I see that you were specifically talking about aluminum wheels, so a lathe would be a necessity
Just once I add up the effort to do just one wheel scares me when I think of doing 10.
I just purchased a set of 4 already made 7" wide sight-unseen so I'll re-evaluate making some of my own until I see a set that are done correctly.
+1.5" inch width, stock dia is all that is allowed for me.
Since I am still 4 lug the options are limited.
I sure wish that the: unicorn, 4X130, 15X7 with 120mm backspace was easier to find.
