Shindog1961
Apr 28 2014, 11:34 PM
Click to view attachmentGot the heads on, getting ready to put the followers in and can only find 7. Should I replace them all or just get another? Seem to be in pretty good shape, no nicks, scratches or dents.
cwpeden
Apr 29 2014, 12:18 AM
No comment on a solution but I feel your pain. I lost a wrist pin on my last rebuild.
SLITS
Apr 29 2014, 08:38 AM
I may have several if you need one. PM me if so.
Cap'n Krusty
Apr 29 2014, 08:45 AM
It's strongly recommended that cam followers go with the camshaft with which they were originally installed. Both work harden and mismatching can, and often will, lead to unforeseen and rapid wear. I have seen old cams and new lifters fail disastrously, once in less than 600 miles. The opposite scenario is also known to have happened. Mismatching is a calculated risk.
Good luck! The Cap'n
