WestTX914
May 1 2014, 12:52 PM
As the title says I'm looking for aset of carbs and a Bursch Exhaust for my 71. Thanks Mike
yeahmag
May 1 2014, 02:57 PM
I have a complete 2L setup including a Bursch I may sell in the near future if you are interested...
WestTX914
May 1 2014, 05:34 PM
my motor actually has less than 5000miles on it but I appreciate the offer
May 1 2014, 05:36 PM
are you looking for driver quality or new?
yeahmag
May 1 2014, 05:38 PM
Sorry, that wasn't clear. I have a complete 2L exhaust set up - not motor.
QUOTE(WestTX914 @ May 1 2014, 04:34 PM)
Redhorseracing
May 1 2014, 09:02 PM
I have a set of Weber 40 IDF Carbs if your interested. I can send some pics if you like!
Thanks,
Blake
WestTX914
May 1 2014, 10:36 PM
[Correct me if I'm wrong the 2.0 setup won't fit on the 1.7l?
WestTX914
May 5 2014, 04:19 PM
I got a set of Carbs still looking for the Exhaust. Thanks Mike
stugray
May 5 2014, 07:42 PM
I have what I believe to be a "bursch":
That appears to be intact (no rust-through) and could use a good coating or paint.
Sorry if I misidentified it.
And I have some SS HEs if you poke around the same area of those photobucket pics.
stugray
May 5 2014, 09:16 PM
Did you need heat exchangers with that?
I have two different kinds (not sure which is which):
The second set is SS and are in great shape.
I dont know which one is correct for your car to fit the bursch.
I also have different kinds of hangers.
WestTX914
May 5 2014, 09:26 PM
I'll check mine tomorrow but I think I'm good. I'll check in the AM thanks Mike
bdstone914
May 5 2014, 09:46 PM
The SS are 2.0 and the steel ones are 1.7 or 1.8.
Match the flange hole pattern of the heat exchanger to the muffler. The hole pattern is different between the two types.
Either can be put on a 1.7 if the correct muffler bracket is used.
