QUOTE(Mike Bellis @ May 1 2014, 08:34 PM)
If you pop them apart, rubber gloves and paper towels will make quick work of most of the grease. Then a follow up with just about any degreaser.
Just did six of them that way and used carb cleaner for what grease was left.
I find it a good practice to mark the orientation of the three main parts and put them back together exactly the same. I use a Dremel to make a small mark on the inner, outer races and cage.
Had many lock up after assembly if pit together differently.
