neo914-6
Jan 14 2005, 02:35 PM
Questions:
1. Will a Boxster tranny simply bolt up to 1.8t or 2.7tt? I hear they do but I need facts.
2. Anything wrong with Tiptronic Boxster trannys?
3. Are 1.8t or 2.7tt engines internally different for automatic trannys? A dismantler told me yes.
4. If 3 is correct, what is the problem with switching them, i.e install a "manual" engine with an auto tranny or an "auto" engine with a manual tranny?
Mueller
Jan 14 2005, 03:19 PM
have you checked out vwvortex.com yet?
they have an audi tech section...someone there might be able to help you....
have you swung on by ATP yet? they had a couple of different audi drivetrains sitting on the shop floor last week....
scotty914
you could always go older tranny, one that does not tie in to the car brain
the audi 5000 trannt looks like a good start,
audi 5000 swapshows some stuff
Scott Carlberg
Jan 14 2005, 03:41 PM
you are asking for 'just' the transmission issue, right?
I mean, the 1.8t is a inline-four,
whereas the 2.7tt is a V6
sorry, IF that's not news to you
andys
Jan 14 2005, 04:05 PM
Felix,
I'm not sure where you're going with this, but I will share what I know.
All later model longitudinal mount inline 4 (1.8t) and V6 (2.7/2.8) motors and transaxles interchange (A4, A6, A8, etc); from about '98 up or so. The transaxle models for manual transmissions will be the 012 5 speed, and the 01E 6 speed, which is only available as a Quattro in the US. The same model transaxles are used in the VW Passat. The earlier model 013, 093, and 016 (Audi 5000) 5 speed transaxles have a different bellhousing bolt pattern, and will not interchange.
I don't have any data on swappping manual and auto transaxles. I suspect you'd only need to change out the normal stuff like flexplates to flywheels, the sandwich plate between the motor bellhousing surface and the transaxle mounting surface (the auto differes in thickness, as do the various motor config's like I4 and V6), and so on. Major swap issue could be auto trans electronics if coupled to the ECU, and for sure the Tiptronic.
The TT is a transverse mounted motor/trans, so they are an entirely different layout. Non of those will interchange with the A4, A6, etc.
This is all from memory, but should be close. Hope it helps.
Andy
lapuwali
Jan 14 2005, 04:18 PM
I'd avoid any of the Tiptronic 'boxes if only because they're all going to involve electronics that MAY be difficult to integrate in with everything else. If they have a completely separate ECU (possible), they'll require some sort of feed on at least vehicle speed, maybe on engine rpm. They may use the engine's ECU, which may get very confused if you try to run it w/o all of the inputs hooked up and working.
Stick to a pre-electronic all-manual gearbox, and you're substantially reducing the headaches in doing the swap.
