QUOTE(jim_hoyland @ May 6 2014, 04:33 PM)
SOAB; I had the car towed last week. The tow-guy pulled the driver side seat belt all the way out looping it through the steering wheel and back to the receiver. Ever since the belt will only travel 6" or so before locking up. Takes me 5 pulls to just reach the receiver.
If it can be fixed, that would be great; if I purchase a replacement, are the retractors specific for left and right sides ?
I've tightened the springs, and has always helped.
You can tighten the spring without taking the spring cover off but will need to take the other cover off to make the process easier.
After you have the big cover off, pull the seatbelt all the way "out" untill you can see the slot where the belt is fastened to the spool. Push the belt back out of the slot (kind of hard to explain), it is retained in the spool in a recess with a pin inside a pocket in the belt. Once you have pushed the belt back thru the slot alittle you can push that pin out of the pocket. Once the pin is out you can pull the belt out of the spool thru the slot. You will have to keep the spool from spinning under spring tension while doing all of this. Once the belt is out, tighten the spool tension until it wont tighten anymore. I usually back off the tension a turn, then reinsert the belt (make sure it goes back thru the slot in the same orientation so you have not reintroduced a twist into the belt), insert the pin, pull the belt pocket and pin back into the recess and let it wind back up.
Sounds way more complicated than it really is. This has improved every belt I have done it on. For the belts in the worst shape that I have worked on, I had to take them completely apart, including removing and rewinding that awful spring, but most belts dont require it. Good luck.
