QUOTE(GeorgeRud @ May 7 2014, 06:11 AM)
I don't recognize the rod you're showing in your picture, but you have to replace all the shifting parts from the shift knob all the way back to the transmission to convert to a side shifter. If you're using the original shift rod, it won't work.
Have you also changed the engine cross bar, brackets that attach the bar to the engine and to the body and motor mounts?
All need to be changed to use a side shift trans. I should have all of those parts if you need them.
Bruce
