My car has an aftermarket electrical windshield washer installed.
However, the power wire is not hooked up. There is a toggle switch on the fuse panel that has all the wires cut off.
I touched the loose power wire against the fuel pump connection, and the washer pump worked, so it's just a matter of reconnecting it properly.
Assuming the toggle switch works, where do I hook up the wire from the toggle switch into the fuse panel?
Thanks in advance!
