QUOTE(Mikey914 @ May 9 2014, 09:21 AM)
The lip is hiding. It's on the fire wall right below the glass. The seal pushes onto this lip. It's easier to see / do without the deck lid in the way. Also note I made te clip section removable on this seal so in the corners if there us a bunch of crud, you can cut out 1/4" of the clip to make it sit flush.
Hope this helps,
Mark
i think my lip has been hammered flat and will need to pry it out,thanks.
