QUOTE(914forme @ May 11 2014, 03:29 PM)
I need a set of 914-4 front A-arms, these need to be -4 so the splines are correct for my 21mm torsion bars. Straight good condition, I will also need the rear T-bar caps.
I have a set of 911s that have ~19mm torsion bars if you would want to trade up.
I have a pair of -4 A arms I will trade for 911 A arms.
Do you have the torsion bar caps for them ?
Do you need the sway bar tabs on them ?
Do the 911 A have the U tab for the through body sway bar or the loop bracket for the under body sway bar ?
Bruce
