QUOTE(metalmorphosis @ May 11 2014, 10:15 PM)
So Dave why would this potentially cause worse bump steer?
Bump steer is changed by changing the height of the steering knuckle relative to the height of the steering rack. It doesn't matter how you do it, if you raise the whole strut or just the spindle.
You are talking about raising up the spindle, and then raising the suspension to lift the car back up to where it was. In that case, the arm will be in the same position relative to the rack. The bump steer will be the same as it had been.
If you change the suspension height somewhere down the road (you want it taller, you want it even lower) you will change the relationship between the knuckle and the rack again. Which means the bump steer will change again.
Note that the changes could be harmful, or could be helpful, or could be not enough to notice. I don't know the specifics, and most people who start thinking about those effects will actually measure them on their own car.
--DD
