QUOTE(rosenfe @ May 14 2014, 03:04 PM)
on my 73 2.0.i have 2 -34 webers with original cam,would like more power without rebuilding or changing cam.still have complete original fi,but it was not running when i got it with the fi,so we put on webers.would i do better going back to the fi,or would larger webers work?
I think most would have you go back to the FI. Webers don't help the power side of things really without a cam change, it was a band-aid for broken FI in most cases. If you want more power really you either need to increase displacement and all the work involved there, or swap powerplant. That also is $$$.
*** I will say that if you wanted a boost in power, bumping from 94 to 96mm pistons seems to be a popular choice. I believe this results in the 2056 displacement you see folks talking about on here. Stock FI seems to need some massaging to take advantage of the displacement increase, but it would work.
