mr914
May 15 2014, 11:12 AM
Pulling apart that Aluminum case 2.0 motor in anticipating to sell it and cant seem to get one of the heads off.
Motor has been sitting for 20 plus years and rotates freely.
4 heads came off with a little more than a ketchup bottle thump.
1 head came off with the cylinder attached
The other one, wont seem to budge. Made sure all washers were removed. been soaking with PB Blaster for a couple of days
BTW: motor had been sitting for several years and a mouse had made a nest on top of that particular cylinder.
Hence - Mouse motor...
Any suggestions?
stugray
May 15 2014, 11:21 AM
I would suggest filling up the cyl with a little oil while at BDC, reinstall spark plug, close valves and rotate motor.
If you did it adruptly (and if there is any compression left) it might pop the head loose.
But if you have already disassembled all the other cylinders, then that might not be easy.
Justinp71
More power!
When I did mine I removed the entire assembly with the 3 heads and cam towers, some light prying was necessary, just be careful not to scratch any important surfaces. If your pulling the barrels off the pistons, maybe see if you can pull the head and barrel of together and then try to knock the barrel off with a mallet.
mr914
May 15 2014, 11:43 AM
Stugray = you may be on the right track.
With no cams etc... Leak down tester and let compressed air move it a bit.
mr914
May 15 2014, 11:44 AM
5 of 6 cylinders heads off
3 cylinders off
Mike Bellis
May 15 2014, 12:17 PM
Put a spark plug back in it at BDC and rotate the crank to TDC. Might pop it off.
mr914
May 15 2014, 12:21 PM
If I was going to do that, shouldn't I remove the other pistons first?
Mike Bellis
May 15 2014, 12:51 PM
QUOTE(mr914 @ May 15 2014, 11:21 AM)
Yes
Jon B
May 15 2014, 01:15 PM
Check to make sure all cylinder head nuts are removed.
With rubber hammer, or metal hammer against block of wood, hit head sideways in both directions several times. It should break bond (not fins).
Jon B.
Vista, CA
KELTY360
May 15 2014, 01:44 PM
Wouldn't the rope trick work? Get piston at BDC, thread a rope into the cylinder through the spark plug hole and then rotate engine. Never done it myself but I've heard it works.
toolguy
May 15 2014, 01:56 PM
do not pry against the cylinder fins, they will break off easily. . If you're sure all 4 head nuts and washers are off, hit it with a RUBBER mallet. . it's better to tap many times than one hard time. . .
I was taught to hit on the top and bottom only which is the way the wrist pin/crank rotates. . . if you hit sideways it can bend the rod. .
Jon B
May 15 2014, 02:23 PM
QUOTE(toolguy @ May 15 2014, 12:56 PM)
...if you hit sideways it can bend the rod.
Bend a rod with a rubber hammer? I don't think so.
The piston has some room to slide, side-to-side, without touching the rod.
If the cylinder can move in the case spigot, it can be pulled off with the head.
Jon B.
Nine_14
May 15 2014, 02:26 PM
If none of the above given suggestions helps, bring the piston to the lowest point,
fill cylinder with water and put the whole package in the freezer for a night and hope
that the soft spot is the head.
mr914
May 15 2014, 02:37 PM
QUOTE(Nine_14 @ May 15 2014, 03:26 PM)
That's a creative approach. I had never heard of that one.
mr914
May 15 2014, 02:42 PM
Confirmed last night that all of the nuts and washers are off.
Using a 1# plastic tipped dead blow hammer with quite a bit of force.
One of the other heads came off with the cylinder attached. This one is stuck on both sides
Penetrating OIL is doing its thing, since last night and will get back to it after 7 tonight.
So far.
1) using a wood block and a bit more force sounds like first option.
2) Putting plug back in and rotating to see if compression will move it.
3) use leak down tester with cylinder at either TDC or BDC and let compressed air do its thing.
Will give those a try.
Thank you for your suggestions.
Scott S
May 15 2014, 02:46 PM
QUOTE(KELTY360 @ May 15 2014, 11:44 AM)
I did this last week to a Jag motor - works awesome. Just enough push to pop it off.
Nine_14
May 15 2014, 02:48 PM
QUOTE(mr914 @ May 15 2014, 10:37 PM)
I never used this method to remove cylinder heads, but it is working fine if you
want to remove dents from motorcycle tanks.
injunmort
May 15 2014, 04:08 PM
gently heat the seam with a torch or heat gun, then tap on it again with the dead blow. the expansion from the heat should free it up. good luck
get off my lawn
May 15 2014, 05:04 PM
M-80 in the spark plug hole.
hey it works on cats and frogs .......
76-914
May 15 2014, 07:04 PM
Anyone that would do that to any animal is a sick fuck and should seek professional help.
Bob L.
May 15 2014, 08:09 PM
QUOTE(76-914 @ May 15 2014, 08:04 PM)
mr914
May 15 2014, 08:17 PM
Hmm.. Will have to post photo of universal cat carrier
just as humor
Disclaimer - no animals were harmed
in producing this thread, however, a few brain cells may have been damaged during the solution of this problem.
Fiddled with the motor some more. Checked for extra washer, pulled pistons from other side.
Rotated offending cylinder to tdc and soaked with pb blaster.
Screwed in leak down testing tool and applied 100 psi. Nice leak from exhaust side.... That's right, this is the dead cylinder
Tapped around with bigger mallet and 2x4. Got slight movement.
Appears top right head stud is corroded to the head.
I can twist the head 2-3 mm but it is bound to the stud
Soaking again tonight and may have to cut the head stud
Unless someone knows how to dissolve rust caused by mouse piss
injunmort
May 15 2014, 08:31 PM
a little heat will cure the oxidation, just say'in
Bob L.
May 15 2014, 09:38 PM
There was a recent thread about using vinegar to dissolve rust. Let it soak for a few hours.
billh1963
May 16 2014, 05:52 PM
QUOTE(76-914 @ May 15 2014, 09:04 PM)
For real .... why would you hurt an innocent frog? A cat, well....
Mblizzard
May 16 2014, 06:06 PM
Don't know if there are enough threads on those studs but do the double nut trick and see if you can rotate the stuck stud.
Yea that wording is likely to come back and bite me!
mr914
May 19 2014, 09:39 AM
Some very good ideas and some unique ones that I had never heard of.
After a couple of days of soaking, trying heat gun and propane torch.
It was time for
I ended up using a auto body saw to cut the cylinder stud. It took 5 blades in all, as the studs are hardened and the saw only has about a 3/8" stroke. Yes I lubed the blade and cutting surface to not harden it.
I am a dosin at the Museum of American Speed and spoke with the engine restoration guys. Their trick chemical is a 50/50 mix of Acetone and Trans fluid.
Not that the head is off, I can try other approaches to removing the stud.
In thinking about this thread, I realized that some of the posters are probably 4 cyl guys and are not familiar with the nuances of a 6 cyl engine. So I drew on a couple photos of 911 heads for reference.
Thanks for all of your input
stugray
May 19 2014, 10:42 AM
Put it in an old crock pot full of vinegar and put it on high for a couple of hours (outside of course:-)
sixnotfour
May 19 2014, 11:52 AM
I have had the same problem, and cut the stud...BTW that appears to have 90mm cylinders, 2519cc , the case has been bored to accept them, heads modified also to accept the bigger bore and later head gasket, or they are later heads, what is the casting year number on them ??
Good Score ..unless you wanted a 2.0-2.4....
Better Decode the engine number, It may be worth way more than you think...911S registry guys are always searching for these early motors these days to complete their numbers matching desire..$$$$
One more thing if that Red fan shroud is correct its a S motor .....$$$
mr914
May 21 2014, 12:12 PM
I decided to disassemble the motor to see what condition it was in. I was considering selling or trading for a correct 2.0 for my 6 or a 3.2.
It was quite a surprise. Thought I was disassembling a 69 2.0T motor.
For a while, I thought I had a 69S motor. Till I cleaned the crud up more and got a good look at the case numbers 901/05
The motor started out life as a 2.0T motor with carbs. We know who the owners were in the mid 80s-present. The car sat for many, many years. We think we know who did the upgrade of the motor, but it has been so long ago, he remembers the car but not what he did to it.
Here is what I know.
Case:
Case type 901/05 Sequence 6692
Case SN: 909442
Case spigots machined for 90mm P&Cs
Has not been modified for piston squirters
Note on case says "case machined .030 for compression
Original oil pump and intermediate shaft - case has not been machined for bearings
Crank and rods
Stroke 70.4
Counterweighted
Rods pn 911.103.105.0R
Heads
32mm ports
40 46 valves
Dual valve springs
No Provisions for Injectors
Part number 911.104.306.0R Looks like casting date was 10/69
According to Bruce's book, it looks like it is an aluminum 2.0 converted to a 2.7
Someone spent a bunch of bucks machining years ago
Jon B
May 21 2014, 08:24 PM
QUOTE(mr914 @ May 21 2014, 11:12 AM)
Case SN: 909442
Nice collection of parts for very strong street motor.
Case number is model year '67 911, not T or S.
Pistons appear to be Euro Carrera 2.7 for MFI, 8.5:1, obviously not CIS pistons.
Heads from carbureted 2.2T, small ports, machined to accept 90mm cylinders.
All 911 engines had dual valve springs.
Cams???
Jon B.
Vista, CA
mr914
May 22 2014, 05:36 PM
Cams
901.105.109.01
901.105.110.01
Date stamped 2/70
Any idea what they are and how I can tell if they were reground?
Original cam specs would help as I could measure to see if they are stock
toolguy
May 22 2014, 05:52 PM
looks like you have Solex Cams. . Great for the street. . A little better than E's but not quite as 'lumpy' as S. . I had a 2.2 with E pistons and Solex cams. . starts pulling hard at 3500 and went to 7200 easily
Jon B
May 22 2014, 06:20 PM
These were "Solex" cams for '67 engine with splash lubrication, not center lube. Same billet numbers.
See chart below, fifth line down, matches your case serial number.
Agree with toolguy, great for street use, roughly between E and S cams.
I don't think "70" number is date code.
Anything stamped on either end?
Click to view attachmentJon B.
Vista, CA
mr914
May 22 2014, 09:01 PM
After cleaning some crud off of the end....
One said "SOLEX"
Sounds like it could be a fun motor.
Would this be considered a 2.7 RS configuration sans MFI?
What type of HP should I expect with webers? And how would it compare to my old 74 2.7 cis car or my 85 911 Carrera 3.2?
Just thinking, have 2.2E with MFI that currently is mounted in the 6...
How tough is it to convert a 2.2 MFI system to 2.7?
Boatloads of cash to obtain un-obtanium parts?
Jon B
May 22 2014, 09:55 PM
QUOTE(mr914 @ May 22 2014, 08:01 PM)
Not quite 2.7 RS.
Ports are pretty small for 2.7, US/CIS ports were 35/35, RS 36/35.
Same valve sizes.
RS had S/MFI cams.
Still basis for very nice motor, if everything in good condition.
Can't mount MFI pump on early case, can't drive pump with carb cams, heads need mod for injectors, etc...
I'd leave 2.2E alone.
Jon B.
Jon B
May 22 2014, 10:30 PM
I built the engine for this '67 911 about 20 years ago.
Same basic 2.7 upgrade, RS p/c, Solex cams.
Scroll down to specs beneath engine photo...
http://www.audettecollection.com/306607/Jon B.
Vista, CA
gandalf_025
May 25 2014, 04:35 AM
I'll throw another 2 cents into this. Not that you asked.... But here it is..
Option 1
Clean up the case and post the engine number in a For Sale Feeler on the Early S and Pelican Sites. Someone with the car this engine belonged to might be interested in buying it back. Early cars are going for stupid money and engines are getting up there also. If it sells, you can build something or buy a running 3.0 or 3.2 with the cash.
Option 2
Send the case out and have oil squirter's installed if they aren't in it already. Have the case mod for a big oil pump done at the same time. There is a guy on Pelican selling 3.6 alloy oil pumps for around 500.00.
Put the early heads on a shelf and pick up a set of late 2.7 heads with bigger valves and ports. They aren't that expensive. Twin plug them. Watch Pelican to find a pair of Electromotive Crank Fire units. JE Pistons and I'd find a 2.0 crankshaft and make it a 2.5 SS
2 months ago I sold my early 65 long block that was made into a 2.5. It had all it's 65 parts except the pistons and cylinders. Case and heads were cut to 2.7.
Center oiler solex cams were still in it too. It sold in 20 minutes. Wasn't even the matching number car owner. Just someone that wanted "period Correct".
I owned that engine for around 40 years and never considered selling it.
In the end, Cash Talked Loudly. Prices on early stuff is still going up it seems.
I'd probably get 2000.00 more if I sold my engine today.
mr914
Jun 12 2014, 02:03 PM
Hmm.....
Now this is a dilemma
Sell or rebuild the motor in this thread.
To fund that rebuild and the completion of the 6, I would need to sell the 2.2E motor with MFI that has not run in 20 years but turns freely
Or Sell/Trade one or the other/both for a 3.2 w/pmo's
Only need one good motor for the 6
Any idea on values? I've searched the web and evilbay and cant seem to find a 2.2R w/MFI
mr914
Jun 12 2014, 02:05 PM
Update:
Had one of the cylinders stuck to the head on disassembly.
Tried the vinegar trick on a old 1.7 head. Works slow but seems to work
Used some PB Blaster on the stuck cylinder. Added a little heat and it came right off.
Still soaking the rusted stud. Only time will tell.
Any suggestions how to clean carbon off of Nakasil Cylinders?
Im thinking oven cleaner and a white scotch brite
