Full Version: clean out gas tank?
RJMII
Any tips on cleaning out the gas tank?
My car was a little fuel starved... discovered debris from sitting for four years.
Drums66
.....I take mine to a good"RADIATOR"shop!
Nine_14
Frictional grinding is a good choice
several superabrasive products are on the market (See Pic.)
Fixing the tank to an old concrete mixer to rotate it, is a cheap and easy way.
Dr Evil
I put a bunch of all nuts and bolts in it and shake it around vigorously until I am satisfied with the results. Then, I coated mine.
RJMII
QUOTE(Nine_14 @ May 17 2014, 12:31 PM) *
I have a box of crushed walnut shells...
Dr Evil
Walnut shells lack mass. Fasteners are heavy.
tomrev
Another choice is a few lbs. of drywall screws; nice sharp, shake the thing around for a few min., and dump them out. I'v also used short length's of chain, followed by acetone rinse, and had very good luck with adhesion.
r_towle
I have used a piece of chain and lacquer thinner...
Chain was easier to get out then lots of little fasteners.
But if you cannot pick up the tank and turn it around, a radiator shop will boil it out for a fee.
jmalone
QUOTE(r_towle @ May 17 2014, 05:05 PM) *
I agree have it boiled out at a radiator shop, well worth the cost. If your DIYing then sharp gravel is an option
RJMII
turns out the tank was clean inside, and somehow my suck-side fuel line to my fuel pump found its way between the tank and the body. :-)
JawjaPorsche
QUOTE(RJMII @ May 17 2014, 08:24 PM) *
