DEC
May 18 2014, 04:08 AM
I got a set of OE 914-6 headers from a car that was involved in
a heavy accident. All Parts from this car are bend incl. the headers
Click to view attachmentClick to view attachmentBecause I build that -6 for my wife as a daily driver heating it is a must have
I desided to cut them off and transfer the parts to
the MSDS headers I got last year from Marty
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentWith a bit addon sheetmetal and a lot of
Click to view attachmentClick to view attachmentClick to view attachmentReady for installation
Click to view attachmentThere are only 2 pipes in use for heat butI think they can not
heat worse than the BB stainless steel headers which
I use on my 6........
Cairo94507
May 18 2014, 07:07 AM
Impressive work. I bet they keep the car nice and warm too.
Dave_Darling
May 18 2014, 11:04 AM
I hope you didn't weld them to the pipes... Those can create pinholes, leading to carbon monoxide poisoning for anyone in the car when the heat is on... Even if there aren't holes now, they can develop later. If you noted the original exchangers, they were a little loose on the pipes--to avoid just this problem.
If you welded them, please please please get a CO detector and use it full-time in the car!!
--DD
Krieger
May 18 2014, 12:18 PM
Sporty Pilot shop has inexpensive ones that work well.
shoguneagle
Sep 26 2016, 12:04 PM
Even with originals, you should run a carbon monoxide sensor!
mb911
Sep 26 2016, 06:49 PM
Pressure check the primarys and you will know if there are pin holes.. In avaiton they are semi loose as well.
