scotty b
Jan 16 2005, 09:48 AM
I'm going to be starting on my dads 72 in a few weeks and was wondering if anyone had come up with a reliable fix for the aerly window regulators jumping out?
I have always just wire tied them from one bolt to the other and around the track,
but this is certainly NOT the best fix!!
dmenche914
Jan 16 2005, 11:18 AM
Wire sounds good to me. i contemplated drilling and putting a pin thru the metal / plastic parts to keep them together, but them I got thinking, maybe it was designed to pop out, such that if a window is forced down, or is stuck from say ice, that the metal part will pop out of the plastic part, thus preventing damage to the drive mechanism (cable, and gears) Problem is that "break away" feasture all too often wears, adn starts to fall apart, and each time you put it back, it wears a bit more, and it don't stay together. So wire it loosely so that you do not risk wrecking the drive mechanism if the window jams.
good luck dave
Jeffs9146
Jan 16 2005, 01:33 PM
I just replaced it with another one from a lower mileage car. Andy gave me a few tips on lubing up the track rollers and it works great now!
Jeff
mightyohm
Jan 16 2005, 01:37 PM
I have early window regs and neither of them have popped out once in 2 yrs.
scotty b
Jan 16 2005, 02:09 PM
You've never gotten mad at your car have you Jeff?? Shut the door a little to hard and POP
markb
Jan 16 2005, 04:32 PM
I had that problem on mine. The fix was to re-glue the metal plates at the lower left of the window. When the plates come loose, the glass moves around, and it won't stay against the winding mechanism, and it jumps out. Re-glue the plates and you should be golden. I took mine to a glass place and had them use the really good stuff. Haven't had a problem since. This presupposes you've cleaned & lubed everything, of course.
scotty b
Jan 16 2005, 04:52 PM
You Cali guys are so zen about this stuff, I wish I could be so.....
