Larmo63
May 24 2014, 01:31 PM
Okay, I now have backfires at the heads since I re-torqued my heads and put on a stock muffler. (1973 1.7L) I want to take the HEs off to inspect and replace with another much better set that came with my car. I have PB Blasted all the nuts, but what are the chances of stud breakage, problems, nut-serts, etc...? Am I opening up a can of worms? Are the copper gaskets readily available at FLAPS?
Advice....?
Dave_Darling
May 24 2014, 02:13 PM
The gaskets will not be available at most FLAPS. You might get lucky, though. Ask them about exhaust gaskets for a 73 VW Bus and just perhaps...
Your odds of breaking stuff are about the same as they are any time you touch the exhaust nuts. Not high, but it's a real PITA if you do break anything.
Go for it.
--DD
Larmo63
May 25 2014, 03:22 PM
I'm ordering new intake gaskets, both sets of O-rings for the injectors, and the big mesh hose sections for the big intake tubes on the top of the motor. Mine feel crunchy. Is this a pretty straightforward install?
