Okay, so I decide to try to find the source of oil leak, using
the fluorescent dye and UV light. I'm using Brad Penn, and
it turns out that it's fluorescent already so adding a small
amount of the dye to 8 qts of oil (6 cyl) doesn't do squat.
I guess that would be good if there was a small leak and
just started happening; but I've had several leaks forever
and the fan has been blowing it all over, so I 'd never get
back to clean enough to use this method.
Unless there is some color dye available other than
yellow-green.
