jacksun
May 25 2014, 07:19 AM
what would be the purpose of the round/square item in the below image??
tks
r
KELTY360
May 25 2014, 07:54 AM
Portal to a 4th dimension?
anderssj
May 25 2014, 08:03 AM
the square peg in the round hole we've all heard about?
r_towle
May 25 2014, 08:19 AM
Draining car when dipped in metal treatment.....maybe
Could also have been to get a spot welder into specific locations.
Steve
May 25 2014, 08:35 AM
I was told they were used by the factory for the spot welder to get access to the panels.
jacksun
May 25 2014, 08:36 AM
tks.
I was wondering is all.
could it be to break up the expanse of the flat area to add structural
strength. also??
jacksun
May 25 2014, 08:38 AM
mostly I am just trying to get my "posts" number higher so I can
get in on the reduced price for parts points list..
r_towle
May 25 2014, 08:51 AM
QUOTE(jacksun @ May 25 2014, 10:38 AM)
Post pics in the hot chick thread....
carr914
May 25 2014, 09:03 AM
That doesn't happen til you hit 50,000! I'm almost there!
PanelBilly
May 25 2014, 09:34 AM
QUOTE(jacksun @ May 25 2014, 07:38 AM)
Discount? All I got was a T shirt
wes
May 25 2014, 10:07 AM
Wow guss I've got a long way to go!
Justinp71
May 25 2014, 10:57 AM
QUOTE(KELTY360 @ May 25 2014, 06:54 AM)
ROTFL
May 25 2014, 01:45 PM
QUOTE(Steve @ May 25 2014, 07:35 AM)
ClayPerrine
May 25 2014, 03:35 PM
Actually I know.
There is a video of them assembling 356s on the line. The 356 has the same type of holes in the panels. The holes are used to lock the panel to the assembly jig, then the body panels are welded together. Once the tub is welded up, the would unlock them from the jig, and lift off the body. Then they put the plugs in and added the seam sealer.
It is clear on the video.
green914
May 25 2014, 03:40 PM
QUOTE(wes @ May 25 2014, 09:07 AM)
How far away is the 4th dimension?
Bob L.
May 25 2014, 11:13 PM
QUOTE(green914 @ May 25 2014, 04:40 PM)
It's all around you, Maaaaan!
jacksun
May 26 2014, 06:47 AM
QUOTE(Bob L. @ May 26 2014, 01:13 AM)
the 4th is just before you "let the sunshine in" with the 5th dimension.
KELTY360
May 26 2014, 11:02 AM
QUOTE(jacksun @ May 26 2014, 04:47 AM)
Groovy tunes of the 60s, rock on!
