Click to view attachmentSorry I am having so much trouble with my old computer (which has the photos, and new Mac for all else). I will add photos as best I can. Car is very solid, still in a pertty stock form. Shocks are Koni on all corners, adj. in rear, along with 200 lb. rear springs. All calipers were new a few years ago, along with some hard bk. lines, and Mintex pads,rear venting distance set, and parking brake works well. No rust anywhere, side valances and front and rear lower val. are powder coated stock steel. Front air dam is P.C. aluminum. Front and rear bumpers are new glass, black jellcoat.Seats are very nice, carpet is new Perlon set, with new dash cap, and 3 extra gauges, (oil pre, coolant temp, and voltm.) in radio hole. All gauges working except tach, which needs the adapter for the LS ECU installed, (included with car) also wipers are not working, but complete wiper motor and linkage included. Engine has full Renegade adapter kit, new clutch, etc., along with their wiring harness, ECU has been reprogramed to omit the stuff no longer needed. Stock LS manifolds are Jet-Hot coated and flow into a pair of new Walker mufflers; quite at cruse, and nice when leaned on! Side shift transaxle was rebuilt by Renegade with their 4 speed conversion and long gearing. I sent it to Bluesky for a fresh look, and all wear items were replaced. Top gear has some whine at cruize despite checking out OK. Polished Fuch wheels, including a 5th for the spare, which is pretty rashed up, but funtional. Rad is complete Renegade set up with fans wired to run independant of ign. switch, and keep the car at 170, or below the whole time I have had her. Original milage is 107K. It was always a Ca. car till I shipped it here to N. Mi. for the conversion. Top will fit in the trunk without interferance with the manifold and air cleaner tubing, which returns into the engine bay. Tires are older Pirelli, but have almost full tread. Both windshield and rear window were pulled for the paintwork, and reinstalled by a pro. Also much new rubber seals from 914 Rubber, including targa top front, fnt. and rear trunk seqals and all door and window seals. She is a nice sleeper, starts instantly like all modern ECU controlled cars. Thanks, Tom 231-946-0724
