914Sixer
May 25 2014, 06:56 PM
I have got a bunch of relay boards, cleaned, stripped and tested. I need to coat the bottoms. I do not think Plasticote will do the job correctly. What are other options? When I was at the phone company we had all kinds of blocking compound.
ConeDodger
May 25 2014, 07:33 PM
I wonder about polyeurathane...
stinkindiesel
May 26 2014, 07:34 AM
How did you get those so clean? Any particular solvent?
Gary
peteyd
May 26 2014, 08:38 AM
This is what I used. One can did two boards I think. So far it is holding up good
Plasti Dip Black Rubber Coating Spray
StratPlayer
May 26 2014, 09:53 AM
I used liquid electrical tape, holding up very well.
jmill
May 26 2014, 10:02 AM
I'd think about going with a 3M product. I use their stuff at work all the time. Not this particular product but it looks like it'll work.
http://solutions.3m.com/wps/portal/3M/en_U...1gv%29&rt=d
914Sixer
May 26 2014, 03:02 PM
Yes, the 3M stuff is what we used at the phone company. You have to be careful though with the resin. You need to block the holes that go through the board where the hold down clips go, alternator plug and voltage relay plug. If you do not it will run out in the clip holes and fill the plugs for the alternator and voltage plugs making them unusable.
A&P Mech
May 26 2014, 03:46 PM
I use this material (
http://www.mcmaster.com/#7467a274/=s4z07k )@ work to pot electronics. It works great for potting computers. It says in the description that it bonds to plastic.
Ray
